[Electrical force] Electrical charge in equilateral triangle
12 replies · 2K views
sea333
In each corner of equilateral triangle there is a charge with 5 nAs. What force works on the e3 charge (see image). Length of a side is 5 cm. e1 is charged with negative charge.
F = (1/(4*Pi*eps0))*(e*e)/r^2
F23 is a force on the 3rd charge from 2nd charge
F13 is a force on the 3rd charge from the 1st charge
Fr is a sum of both (Pythagorean theorem).
Doesn't Pythagoras only apply to right-angled triangles?
I will check if forces are right-angled
PeroK said:
There is a generalisation called the "rule of cosines", which is very useful.
I have used Cosines to calculate Fr and I still don't get the correct result:
Should I use the Law of cosines ? c^{2}=a^{2}+b^{2}-2ab*cos
Then I would need angle gamma?
I have updated the picture
I have used for gamma = 60 and got correct result but how do you know that gamma = 60 ?
I don't know why I thought that any of the angles is 90 degrees.
The correct result:
If you want to use Pythagorean theorem or Cos/Sin function you need one angle to be 90 degrees.
