Electrical Potential - Difference, Field
Potential difference, denoted as "U" or "V," represents the difference in electric potential between two points, allowing current flow. Electric potential in a field is also represented by "V," indicating a relationship between the two concepts, where potential difference can be expressed as V2 - V1. The equations for potential difference vary based on the system analyzed; for example, V=IR applies to conductors, while V=Q/4∏εr is used in electric fields. Voltage (U) is often understood as the potential difference relative to a defined ground, clarifying the distinction between U and V. Understanding these relationships helps clarify the concepts of electric potential and potential difference in various contexts.
Hunt4Higgs
Yet another quick one I bet one of you will be able to explain in twenty seconds.
Going over Electric on my own and I've come across the basics of Potential Difference, when looking at it between points (not in a field) it is defined as electric potentials being different at two points creates a potential difference which allows the flow from one point to the other. Potential difference is represented by "V" in both of my textbooks (I know it is U in other places).
Now skipping ahead slightly and I meet Electric Potential in a field. Also denoted by "V". Is this due to a relation between the two?
Is it as simple as Potential Difference is a change in Electrical Potential between the two points (a difference of V between the two points?), so you "could" say it as V2 - V1? Hence why they are both called V?
As a similar point, are the equations for the types of P.d different due to looking at different "systems", i.e. when the equation V=IR is used, this is because you are looking at a conductor which will have a voltage drop associated with it?
Whereas when you are looking at an electrical field, the equation V=Q/4∏εr is used because...?
Cheers guys/girls. :)
Hi Higgs, what are you doing here? You should be at CERN right now :smile:. You said:
You are correct/on the right path. The sometimes sloppy use of variable names add to the confusion.
U = ΔV = Voltage = Potential Difference
V = Electrical Potential
Both are measured in Volts. In electrical engineering the voltage U is usually understood as the potential difference between let's say the potential V1 and a defined ground (let's say V2=0 Volt). If so, U = V1, since U = V1 - V2 = V1 - 0 = V1. Thus, obviously U≠V1 if the ground V2≠0.
You can make a pretty similar comparison with distance and position. U (voltage) is similar to distance, and V (potential) is similar to position. To measure a distance, you need two positions.
Considering the equation V=IR, I prefer U=IR as U means voltage here. ΔV = IR is fine too.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
