Electricity generator theory question
Factors influencing a generator's output include the rotational speed of the magnets and the number of turns in the wiring, which are directly proportional to the output. Increasing the rotational speed of the rotor can enhance the output, provided all other variables remain constant. The relationship between speed and output can be significant, especially when using gears to multiply the rotational speed. However, the additional work required to increase the speed must also be considered. Overall, understanding these dynamics is crucial for optimizing generator efficiency.
elitt222333
What are the factors that influence a generators output (efficiency?). Does the rotational speed of the magnets influence output? If so, by what magnitude can this be increased? ie. If a system is running at x rpm by what relation can the output be increased if the rotational speed is through the use of gears to 5x... 10x... etc. This may be vague but I am just wondering about the concept. Thanks!
There's a brief discussion about efficiency part-way down this wikipedia intro article:
http://en.wikipedia.org/wiki/Electrical_generator
Thanks for the response! The article was helpful but in re-reading my original post I realized I had worded it wrong. My question should have been: In a system with a predetermined output, and all variables remain constant, would simply increasing the rotational speed of the rotor (be it a conductor in a magnetic field or magnets in a conductive field) increase the output? I read in the article about the number of turns in the wiring being directly proportional to the output, but it did not mention the effect of rotational speed as it relates to output.
*All variables remain constant not taking into account the additional work applied to increase the rotational speed
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
