Electricity Problems - conductive spheres
Sphere X, initially charged to 10,000 volts, is connected to sphere Y, allowing charge to redistribute until both spheres reach the same potential. After disconnecting and connecting sphere Y to sphere Z, sphere Z will also equalize its potential with sphere Y. The potential on sphere Z is determined to be 5,000 volts, and the charge on sphere Z is calculated to be +¼ Q. The process illustrates the principles of charge distribution and potential equalization in conductive spheres. Understanding these concepts is crucial for solving similar electrostatics problems.
big_boi
Initially, metal sphere X is charged to an electric potential of 10,000 volts, with a total charge on its surface of +Q. Metal spheres Y and Z are initially uncharged. Spheres Y and Z are the same size as sphere X. All three spheres are held by insulated stands.
6. Sphere X is connected by a conducting wire to sphere Y. The wire is then removed and used to connect sphere Y and Z. After the wire is again removed, what is the potential on sphere Z?
a. 10,000 V
b. 5,000 V
c. 2,500 V
d. 1,250 V
e. 0
7. What is the charge on sphere Z after the procedure described in problem 6?
a. +Q
b. + ½ Q
c. + ¼ Q
d. + 1/3 Q
e. –Q
Is it A and C?
Connecting two spheres will cause charge flow till both have equal potentials. In short answer is C and C.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
