Understanding Voltage Rating for Electro-Mechanical Solenoids in Robotics
  • Thread starter Thread starter abs_vicky
    Solenoid
The voltage rating of an electro-mechanical solenoid is the constant voltage required to produce its rated current, which is influenced by the solenoid's resistance and inductance. When designing a solenoid, it's important to apply a voltage higher than the rated voltage to achieve the desired current quickly, often using techniques like PWM for current limiting. The relationship between voltage and current is governed by the equation E = L di/dt, indicating that faster current changes necessitate higher voltages. For example, a solenoid with a resistance of 5 ohms and a current rating of 1 amp has a voltage rating of 5V, but typically requires over 20V for optimal performance. Understanding these principles is crucial for effective solenoid design in robotics.
abs_vicky
I m designing an electro-mechanical solenoid as the shooting mechanism in a robot. Its input is DC current. But, my guide asks me to mention its voltage rating. What is this and how to find it out?
Hrmmm, I am prolly going out on a limb here, but aren't all solenoids "electro-mechanical"? The purpose of a solenoid is to generate linear mechanical force from an electric current.
That aside, E = L di/dt . This implies that a change in current has a corresponding change in Voltage. The faster the current changes, the higher the voltage, and the higher the voltage, the faster the current changes.
All real-world, non-superconductor inductors have some resistance. The voltage rating is typically the constant voltage that produces the rated current. In practice the applied voltage is considerably higher than the "rated voltage" to achieve the rated current in a shorter period of time. The rated current is then maintained via PWM or some other current limiting scheme.
So, if your coil has a resistance of 5 ohms and a current rating of 1 amp, then the voltage rating is 5V. You would typically apply >20V to the coil for some period of time ( this figure is actually dependent on the coil's inductance) and then you would use some current limiting scheme for the remainder of the conduction period.
At least this is my impression of "voltage rating" with respect to an inductor. I am sure others will correct me if I have this wrong.
Fish
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
