Electromagnet Materials: Can They Stay Magnetized After Current is Switched Off?
Certain materials can become magnetized quickly when current flows through a solenoid and may retain some magnetization after the current is switched off, primarily due to hysteresis. However, using this retained magnetism to attract magnetic materials raises concerns about energy loss, as the presence of these materials can resist the initial magnetization, leading to inefficiencies. The energy stored in the inductor while current is flowing does not return to the battery but is instead used to attract magnetic materials. This process highlights the challenges of attempting to derive more energy from the system than initially input. Overall, while the concept is theoretically intriguing, practical limitations hinder its feasibility.
jonnyk
Hi everyone,
Is there a material which, inside a solenoid, immediately or in a very short period of time gets magnetized as current is switched on and then stays magnetized for a while if the current is switched off? For if this were true then this would mean we could derive more energy out of the system as we put in. We magnetize the material, switch off the current then use that magnet to attract magntic material to it and derive energy from it. Then as the material is demagnetized after some time we can with much less energy remove the materials which were initally attracted to the temporary magnet. Then repeat the process. Wherein lies the problem?
jonnyk said:
… switch off the current then use that magnet to attract magntic material to it …
but wouldn't the presence of that magnetic material resist the current, so that it magnetised the magnet less in the first place, thereby losing energy?
Permanent magnets are made by the process you describe. Every ferromagnetic substance will retain magnetic field due to hysteresis. Now you say we take an inductor put in magnetic energy, switch of the current. Now when you are putting in magnetic energy[1/2Li^2] this energy is not being given back to the battery rather it stays in the inductor and this is the enregy that is being used to attract magnetic materials.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
