Electromagnetic induction question
4 replies · 2K views
e44-72
Hello
I am new to this forum and wanted to ask a question on em induction.
I know if a current passes through a wire a magnetic field around the wire is produced and can be amplified by having a coil of wire. If that is then placed in a magnetic field (like between a north and south pole magnetic) motion will be produced.
With induction if a wire/coil experiences a change in magnetic field by movement of either magnet or wire, then a voltage/P.D will be produced and maybe current if it is connected to a load.
What I want to know is if current does flow through the coil during em induction when a voltage is being produced by the coil/wire will there be a magnetic field produced around the coil/wire itself as current is flowing through it?
Thank you for reading and any replies.
Can you add some punctuation marks? It is hard to read your post.
If a current flows through a coil, it produces a magnetic field, even if there are other external magnetic fields or anything else.
Sorry my question is confusing.
If current flows through a coil, (like from a battery) then is produces a magnetic field.
So if I move a coil in a magnetic field, to create a current flow through the coil will it also turn into a magnetic?
Thank you for the answer mfb.
e44-72.
