Transforming E and B in Electromagnetic Waves Through Moving Media
bernhard.rothenstein
Please consider the following problem:
A plane electromagnetic wave propagates throug a stationary medium with phase velocity u<c. Consider an observer that moves with speed u relative to the medium. In
J.P. McTevish, "Maxwell's equations in media and special relativity," Eur.J.Phys. 21 229-231 2000
the Author mentions that the observer will detect the presence of a magnetic field and the absence of the electric field.
My intuition (which is not the best adviser) suggests that he will detect the presence of the static electric field and the absence of the magnetic field.
What is your oppinion and why?
Thanks
It is not as easy as that article (which I have not see or refereed) says.
You know E and B in the rest system of the dielectric as functions
of r and t. You can LT E and B, and r and t to find E and B in the moving system. It is straightforward, but could be complicated algebraicly
E and B transformation
Thanks for your hint. I have realized thatg static E and B and E and B in the electromagnetic wave transform in different ways.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
