Electromagnetism and charged particles in motion
Charged particles in motion generate both electric and magnetic fields simultaneously. The study of these fields often focuses on one at a time due to historical inertia, as electric and magnetic forces were discovered through different phenomena. This approach also serves educational convenience, allowing students to grasp simpler concepts before tackling more complex scenarios. Initially, students learn about isolated electric or magnetic fields, which prepares them for advanced topics involving the unified electromagnetic field. Ultimately, understanding both fields together is essential for a comprehensive grasp of electromagnetism.
toumaza
Whenever a charged particle is in motion ,there is both electric and magnetic fields created. Why is it that we only study one of it at a time ?
Historical inertia. Electric and magnetic forces were originally discovered in different phenomena.
Some of it just convenience in learning. Students have to start somewhere, and the easiest problems are the ones in which only one of the two fields appear. Once the student has a solid grasp of these, they're ready to move on to more advanced problems in which both fields are present and treated as a single electromagnetic field.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
