Electromagnetism and Polarisation question
The discussion focuses on the effects of a uniform electric field on diamond, specifically examining the induced dipole moment per unit volume, which is calculated as P_{0} = 1.5 × 10^{-7} C m^{-2}. The density of diamond is noted as 3500 kg m^{-3}, leading to the calculation of carbon atoms per cubic meter as 1.8 × 10^{29} atoms m^{-3}. The average induced dipole moment is determined to be 8.3 × 10^{-23} C m, and the average separation of charges is estimated at 8.6 × 10^{-5} m. The discussion highlights the discrepancy between the calculated dipole moment length and the expected atomic radius of carbon in the diamond lattice.
  • Understanding of electric fields and their effects on materials
  • Familiarity with dipole moments and polarization concepts
  • Knowledge of Avogadro's constant and its application in calculations
  • Basic principles of atomic structure, particularly regarding carbon
  • Explore the relationship between electric fields and polarization in dielectric materials
  • Learn about the calculation of dipole moments in different materials
  • Investigate atomic radii and their implications in solid-state physics
  • Study the effects of alternating electric fields on polarization current density
Students and professionals in physics, materials science, and electrical engineering who are studying the effects of electric fields on dielectric materials, particularly diamond.
jazznaz
When a uniform electric field is applied to diamond, the induced dipole moment per unit volume (ie. polarisation) is P_{0} = 1.5 \times 10^{-7} \text{C m}^{-2}. Given that the density of diamond is 3500 \text{kg m}^{-3}, 1 kmole of diamond has a mass of 12kg. Avogadro's constant is 6 \times 10^{26} \text{kmol}^{-1}, the atomic number of carbon is 6.
How many carbon atoms are there per cubic metre?
What is the average induced dipole moment?
Estimate the average separation of the +ve and -ve charges.
If P = P_{0} \sin \omega t as a result of the alternating electric field, evaluate the peak value of the resultant polarisation current density, J, at a frequency of 10^{12} \text{Hz}
First part,
\rho = \frac{m}{v} = 3500
m = 3500
m/0.012 = 291666.67 \text{moles}
291666.67 \times 6 \times 10^{23} = 1.8 \times 10^{29} \text{atoms m}^{-3}
Second part,
Average induced dipole moment is total polarisation divided by number of atoms,
= \frac{1.5 \times 10^{7}}{1.8 \times 10^{29}}= 8.3 \times 10^{-23} \text{C m}
Third part,
Dipole moment is \vec{p} = q\vec{L}
So L = \frac{p}{q} = \frac{8.3 \times 10^{-23}}{6 \times 1.6 \times 10^{-19}} = 8.6 \times 10^{-5} \text{m}
Which strikes me as far too small to be an estimate of the atomic radius of a carbon atom in the diamond lattice. I can't see where I've gone wrong, maybe I've missed a subtlety in the question?
Any comments would be great, thanks...
The avergare dipole moment is not the atomic radius of the atom. The value you obtained on the order of 10 microns is much larger than then atomic radii on the order of nanometers.
In this case, the dipole is between the carbon nuclei and the surrounding electron cloud, so I expected the dipole moment to be acting over a length similar to the atomic radius.
Keep in mind an external electric field is applied thereby applying a force to the charges.
  • · Replies 16 ·
  • · Replies 16 ·
