Converting Electronvolt to Joule/Mole for Silicon Material: A Quick Guide
  • Thread starter Thread starter omidd
To convert electronvolts to joules per mole for silicon, the conversion factor of 1 eV equals 1.6 x 10^-19 J is essential. For 4530 eV, the calculation involves determining the energy per mole by considering the number of silicon atoms and their mass. The discussion highlights a calculated energy of approximately 16.85 kJ/mol, though some participants suggest a recalculation yielding 16.168 kJ/mol. The energy value of 4530 eV is associated with the enthalpy change during the melting of silicon. The conversion process can be streamlined using Avogadro's constant to simplify calculations.
omidd
Dear Friends,
Could you tell me how I can convert electronvolt to joule/mole for silicon material? I want to convert 4530 ev to joule/mole for silicon.
Many thanks in advance.
Chemistry news on Phys.org
The trick I like to use is to "substitute" the units.
Recall that 1.6*10^-19 J = 1 eV
We can write 6.7 eV as 6.7 * 1eV. Substitute the 1eV from earlier and you get 6.7*1.6*10^-19 J.
I'll leave the rest as an exercise, but if you get stuck, try thinking for how much silicon the 4530eV is for.
Thank you for your respone.
I calculated it. Is that correct?
number of atoms = 27000
silicon mass = 28.0855*1.66054*10^-27 Kg
1 Kg silicon = 35.6 mole
(4530*1.6*10^-19)/(27000*28.0855*1.66054*10^-27 ) = 600 KJ/Kg
600/35.6 = 16.85 KJ/mole
I have a few questions:
1) What is the energy of 4530eV for? Is it for some atomic transition?
2) Where did the number of 27000 atoms come from? Is the 4530eV for 27000 silicon atoms?
thanks for your help.
1) That is enthalpy when the solid melts.
2) 4530 ev is for 27000 atoms.
Yes, your calculation seems correct, but a few things to consider:
1) You might want to check the math again. I obtained 16.168 kJ/mol. The discrepancy might be because you approximated the value to be 600J/kg.
2) From wikipedia, we have:
1 kJ·mol−1 is equal to 0.239 kcal·mol−1 or 1.04×10−2eV per particle.
So, if this is one way to convert if you have good memory!
3) While your calculation is correct, I find it rather long. In fact, if you notice, 1/(35.6(mol/kg)*28.0855*1.66054*10^-27(kg))=6.023078*10^23 /mol, which is the Avogadro constant!
4) In view of point 3, in fact, you can directly compute using (check units by cancelling them like in fractions):
4530eV/270000atoms * 1.6*10^-19 (J/eV)* 6.022*10^23 (atoms/mol) = 16.168kJ/mol.
Indeed, 1.6*10^-19*6.022*10^23 = 96352 J/mol, which converts 1.04*10^-2eV to 1kJ/ mol in point 1!
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
