Electrostatic equilibrium (Sphere with cavity)
The discussion revolves around a conductive sphere with a concentric cavity and the effects of introducing a charge into the cavity. Initially, the electric field at the outer surface is 450 N/C, corresponding to a charge of 2.0 x 10^-9 C on the outer surface. After introducing a charge of 1.2 x 10^-9 C into the cavity, the electric field decreases to 180 N/C, prompting a reevaluation of the charge distribution. Participants clarify that the charge on the inner surface becomes equal and opposite to the introduced charge, while the outer surface charge adjusts accordingly. The conversation emphasizes the relationship between electric fields, charge distribution, and the principles of electrostatic equilibrium.
Fabio010
Consider a sphere conductor with a inner concentric sphere cavity. The radius of the inside and outside of sphere are 10 cm and 20 cm. The electric field in a point P, along the outer surface has a intensity of 450 N/C and it is directed out of the surface. When a particle of unknown charge is introduced into the center cavity, the electric field continues to point outward from the surface but its intensity is now 180N/C.
a) Which was the total charge of the sphere before being introduced charge Q?
b) Which is the value of charge Q?
c) After the introduction of the charge Q which is the value of the charge on the
inner surfaces and outside conductor?
a)
Qint = -\sumqi
qi = charge inside cavity
Qint = charge between 10cm to 20cm
Qext = Outside charge
Q = Qint = Qext
The Electric field outside sphere is E = k*q/r^2
so
450 = k*q/(0.2)^2
q = 2.0 * 10^-9 C
then Qint=Qext 2.0 * 10^-9 C
b)
Qint = -\sumqi
E = k*q/r^2
180 = k* (2.0 * 10^-9 + x)/(0.2)^2
x = -1.2E-9 C
The introduced charge in cavity is 1.2E-9 C
c)
Qint = -\sumqi
2.0 * 10^-9 + x = -\sumqi
2.0 * 10^-9 - 1.2E-9 = -\sumqi
-\sumqi = 8 E -10C
Qint = 8 E -10 C = Qext
Q = Qint = Qext
Qint is the charge on the inner surface, no? It won't equal Qext. Did you mean Q = Qint+Qext?
c)
Qint = -\sumqi
-\sumqi = 8 E -10C
I don't understand your calculation here. Isn't Qint just equal and opposite to the introduced charge? And Qext is whatever is left over from the original charge?
sorry you right.
The electric potential outside sphere is ke*Q/r^2
\sumqi are the sum of the charges inside the sphere.
The outside charge is Qext
450 = k*q/(0.2)^2
Qext = 2.0 * 10^-9 C
I just said that the Qint in always the same. The electric field is the only that is diffrent because it varies with the radius.
so Qint (inner surface (10-20 cm) is equal to Qext (20 to infinity)
right?
When the outside electric field(along the surface = 0.2 cm) is 180, then:
180(4*pi*(0.2)^2) = Q/εo
so Q is now 28.8*pi*εo C
The introduced charge is positive
is the difference ( 2.0 * 10^-9 C - 28.8*pi*εo C)
450 = k*q/(0.2)^2
I'm finding your use of variables confusing still.
Before the introduced charge, there will be a charge of 2.0 * 10^-9 C on the external surface of the sphere (call this Qext, but this is right at 20cm, not 20 to infinity). Let's write Qint = 0 to represent that there is no charge on the internal surface (i.e. at 10cm, not 10-20 cm) at this time.
After the charge is introduced, there will be different charge Qext' on the external surface and a nonzero charge, Qint' on the internal surface.
What will Qint' be, and having determined that what will Qext' be?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
