How Do You Calculate Electrostatic Force Between Charges?
The discussion focuses on calculating the electrostatic force between two positive point charges of 1.5 × 10−9 C, positioned at y = +0.50 m and y = −0.50 m, with a third charge of 1.0 × 10−9 C located at x = 0.55 m. The Coulomb constant used is 8.98755 × 10^9 N · m²/C². The initial calculation of the force was incorrect due to neglecting vector addition and the y-components of the forces. The correct approach involves treating the forces as vectors and considering the geometry of the charge placement.
  • Understanding of Coulomb's Law and electrostatic forces
  • Familiarity with vector addition in physics
  • Basic knowledge of charge placement in a coordinate system
  • Concept of electric field and force diagrams
  • Study vector addition of forces in electrostatics
  • Learn about the implications of charge placement on force calculations
  • Explore the concept of electric fields and their calculations
  • Investigate the speed of electrostatic interactions and related concepts in electromagnetism
Students and professionals in physics, particularly those studying electrostatics, electrical engineering, and anyone involved in calculations related to electric forces and fields.
BoldKnight399
Two positive point charges, each of which
has a charge of 1.5 × 10−9 C, are located at
y = +0.50 m and y = −0.50 m.
The Coulomb constant is 8.98755 ×
10^9 N · m2/C2.
a) Find the magnitude of the resultant elec-
trical force on a charge of 1.0×10−9 C located
at x = 0.55 m.
Answer in units of N.
So I drew out a force diagram and thought that the equation would be:
Fel=kc(Q1*q/d1^2)+kc(Q2*q/d2^2) where the q is the 1.0e-9C charge.
Fel=(8.98755e9)(1.5e-9*1.0e-9/.0025)+(8.98755e9)(1.5e-9*1.0e-9/1.1025)
so Fel=5.404757e-6
Apparently that was the wrong answer. Does anybody know or want to explain how I should now re-examine the problem?
The force from each charge is a vector. You have to add them like vectors, not numbers--the direction matters. Hint: What happens to the y-components?
Also: What's the distance between the charges?
yeah...I missed the fact that q was on the x axis. makes sense now. Thank you for your help!
I have a question about the operation of the electrostatic force. I solved the Maxwell's equations in a pure static electric conditions and the result I got does not look like a wave equation. If that is the case, then what is the speed of electrostatic interaction in free space? And what is the messenger particle?
