Electrostatic Force: Finding mA:mB Ratio
13 replies · 3K views
peterpang1994
I have some problems withe this question:
Two positively charged particles A and B of masses of mA and mB respectively are suspended by two insulating threads of the same length from O. Due to the electrostatic repulsive force between A and B, threads from AO and BO make 30 degrees and 60 degrees respectively with the vertical as shown. Find the ratio mA:mB
I can find mA+mB but I can't find mA:mB
(the correct answer is 31/2 : 1)
welcome to pf!
hi peterpang1994! welcome to pf! :smile:
(have a square-root: √ and a degree: ° and try using the X2 icon just above the Reply box :wink:)
Show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
thanks a lot tim,
First I let the electrostatic force be F, TA and TB be the tension of the threads linking the ball A and B respectively and θ be the angle between the vertical and the electrostatic force . And the balls are steady.
Horizontally,
TAsin30°=Fsinθ=TBsin60°
TA=(TBsin60°)√3
TA=(TB)√3
Vertically,
TAcos30°=Fcosθ + mAg
TBcos60°=Fcosθ - mBg
(TAcos30° + TBcos60°)/g = mA + mB
mA + mB = 2TB/g
I am stuck here.
Yes θ is 75° , the balls are consider as point masses
that is unknown
the distance between the centre of mass and the ball A (R) and d be the distance between ball A and B (r) :
R = mBr/(mA+mB)
I still have no idea with this question, I just keep on asking how come this mc so difficult
If I take the ball A as the center of rotation, the net moment = 0 ,
rTBsin45°=rmBsn75°
mB=TBsin45°/sin75°
If I take the ball B as the center of rotation, the net moment = 0 ,
rTAsin45°=rmAsn75°
mA=TAsin45°/sin75°
mA/mB = TA/TB = √3
thanks a lot! But is there any other simple way to solve this MC? Since that is just a MC in my book??
peterpang1994 said:
… thanks a lot! But is there any other simple way to solve this MC? Since that is just a MC in my book??
(what's an "MC" ? :confused:)
it is simple! :smile:
you didn't need to use the tensions, did you? :wink:
MC is multiple choices question . But this MC is inside the chapter about electrostatic force. I did try to find the tension T.T
