Electrostatic Potential in Electric Fields
The discussion focuses on calculating the electrostatic potential and electric field at the center of a square formed by four charged particles in two different arrangements. In Arrangement 1, where charges of the same sign are at opposite corners, the electrostatic potential is zero due to cancellation. In Arrangement 2, where positively charged particles are on the left and negatively charged particles on the right, the participants discuss using the equation E = k * |Q| / r² to determine the electric field strength, emphasizing the importance of vector representation for accurate calculations.
  • Understanding of electrostatic potential and electric fields
  • Familiarity with vector analysis in physics
  • Knowledge of the Pythagorean theorem for distance calculations
  • Basic grasp of Coulomb's law and its applications
  • Calculate electrostatic potential using V = PE / q for various charge configurations
  • Explore vector addition techniques for electric fields from multiple point charges
  • Investigate the effects of charge arrangement on electric field strength
  • Learn about the implications of symmetry in electrostatics
Students studying electrostatics, physics educators, and anyone interested in understanding electric fields and potentials in multi-charge systems.
krosenberg
1. Four charged particles are held fixed at the corners of a square of side s. All the charges have the same magnitude Q, but two are positive and two are negative. In Arrangement 1, shown below, charges of the same sign are at opposite corners. Express your answers to parts a and b in terms of the given quantities and fundamental constants.
a. For Arrangement 1, determine the following.
i. The electrostatic potential at the center of the square
ii. The magnitude of the electric field at the center of the square
2. The bottom two charged particles are now switched to form Arrangement 2, shown below, in which the positively charged particles are on the left and the negatively charged particles are on the right.
b. For Arrangement 2, determine the following.
V = PE / q
1) I am thinking the the potential at the center, as well as the electric field strength, is zero, since the positives and negatives cancel each other out.
Arrangement 1: Correct!
Electric field strength is a vector or a scalar?
vector; I am not sure how to express my answer for arrangement 2 with the variables (i get frightened without numbers!)
Thanks
Plot 4 vectors, one for every electric field strength. The magnitude of each field is
E=k\,\frac{|Q|}{r^2}
can you calculate the distance r, from the enter to each charge?
using the Pythagorean theorem, would r = sqrt(1/2) x s ? or am i going in the completely wrong direction? its really hard to focus on this stuff during christmas break :)
Actually r=\sqrt{\frac{s}{2}} since it's side is s.
Did you plot the vectors at the center?
yes, would it be like this? (attached .gif)
If there are 4 vectors, two pointing at the one -Q charge and two more pointing at the other -Q charge it is correct!
I can't see the attachment yet! :smile:
  • · Replies 22 ·
