Electrostatic Potential / Work Question?
The discussion revolves around calculating the distance an electron, initially positioned at 20 m on the x-axis with a velocity of 350 m/s, approaches the origin when influenced by the electric fields of a proton and another electron located at -1.000 m and +1.000 m, respectively. The potential energy (U) was calculated using the formula U = k q1 q2 / r, resulting in U = 1.16*10^-30 J. The electric field (E) was determined to be -7.22 * 10^-12 N/C, leading to the work done (W) being calculated as W = qEx. Ultimately, the distance to the origin was found to be 1.004 m, with the initial kinetic energy (KE) not directly influencing the final distance calculation.
  • Understanding of electrostatics, specifically Coulomb's law.
  • Familiarity with potential energy calculations in electric fields.
  • Knowledge of kinetic energy formulas and their applications.
  • Ability to perform integral calculus for work done in electric fields.
  • Study the principles of Coulomb's law and its applications in electrostatics.
  • Learn about electric fields and their calculations using E = kq/r.
  • Explore the relationship between kinetic energy and potential energy in conservative fields.
  • Investigate the concept of work done in electric fields and its mathematical derivation.
Students studying physics, particularly those focusing on electrostatics, as well as educators seeking to clarify concepts related to electric forces and energy calculations.
lightofthemoon
An electron and a proton are held on an x axis, with the electron at x = + 1.000 m and the proton at x = - 1.000 m. If a second electron is initially at 20 m on the x axis, and given an initial velocity of 350 m/s towards the origin, it does not reach it. How close to the origin does it come?
U = k q1 q2 / r
W = q ∫ E dl
E = F / q
KE = .5mv^2
[/B]
I'm not quite sure how to approach this problem...
Calculate potential energy of the second electron:
U = k q1 q2 / r
U = (k * (1.6 * 10^-19) ^2 / 19) - (k * (1.6 * 10^-19) ^2 / 21)
U = 1.16*10^-30
Calculate initial kinetic energy
KE = .5mv^2
KE = .5 * 9.11 * 10 ^-31 * 350^2
KE = 5.58 * 10^-26
Calculate work needed to be done to bring it to the origin
not very sure about this part
W = q ∫ E dl
since all of this is done on x-axis I think the equation will simplify to W = qEx ?
E = kq / r
E = (9 * 10^9 * 1.6 * 10^-19 / 21) - (9 * 10^9 * 1.6 * 10^-19 / 19)
E = -7.22 * 10 ^-12
W = 2.3* 10^-29
From here I'm not quite sure how to continue...
I got the right answer through U / qE = x
Answer was 1.004 m
But can someone explain why I didn't need to use the initial speed of the electron? (Or did I actually need it and just got the right answer by chance?) Thank you
Answer was 1.004 m
It is not clear what you did to get the answer. In your original attempt you calculated the initial KE. Did you use that?
Please post all your working.
No, I didn't use the initial KE at all.
Work to bring the particle to the origin = qEx
So I set U=qEx and solved for x (how far it would get to the origin)
x = U / qE
E = kq / r E = (9 * 10^9 * 1.6 * 10^-19 / 21) - (9 * 10^9 * 1.6 * 10^-19 / 19)
E = -7.22 * 10 ^-12
U = k q1 q2 / r
U = 1.16*10^-30
1.16*10^-30 / (-1.6 * 10^-19 * -7.22 * 10 ^-12 ) = x
x = 1.004 m
  • · Replies 22 ·
  • · Replies 34 ·
