Calculating Electrostatic Force on a Charged Particle Near a Flat Surface
  • Thread starter Thread starter huzzi.123
    Electrostatics
huzzi.123
A particle of charge +q is a distance r away from a charged flat surface and experiences a force of magnitude F pulling it toward the surface. What is the magnitude of the force exerted on a particle of charge +q that is a distance 2r from the surface?
F=KQ1Q2/r^2
E=F/q
E=Kq/r^2
The coulomb's formula seems to fit in i.e F=KQ1Q2/r^2
but I stopped solving it further since Q2 or the value of any other charge isn't mentioned in a question. Anyone please help me do this question?
Thanks.
Well the question seems rather ambiguous as it doesn't say whether the plate is infinite in area, and if it isn't, just how large is it compared to the distance r. If you assume it's the former, and also assume the charge distribution on it is homogenous, you should start by finding the electric field due to the plate at an arbitrary distance from it using Gauss's law, and then find the force using the equation \vec{F}=q\vec{E} (you can also find the field using Coulomb's law, but the procedure is a bit more complicated).
You mean by applying the formula ; E= charge density/permittivity?
The answer should be F/4, isn't it?
I agree with kontejnjer: If you assume an infinite plate with uniform charge distribution, then you can find the E-field it produces using Gauss' Law. It is not quite the result you stated above.
That's what I got after working out my intuition but unfortunately this isn't a right answer.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
