Elevator going up with constant velocity but changing acceleration
The discussion revolves around calculating the total time an elevator takes to ascend 180 meters, involving three phases: acceleration at 1.0 m/s², constant speed at 9 m/s, and deceleration at -1.0 m/s². The initial calculations indicate that the elevator accelerates for 9 seconds, covering 40.5 meters during this phase. The remaining distance of 139.5 meters is to be addressed during the constant speed and deceleration phases. The participant expresses uncertainty about the correct application of kinematic equations for the deceleration phase, leading to confusion with the results. The overall approach to solving the problem is acknowledged, but further clarification on the calculations is needed.
alexs2jennisha
An elevator goes up 180 m by first accelerating at a constant rate of 1.0 m/s2, then staying at a constant
speed of 9 m/s and then decelerating at a constant rate of -­‐‑1.0 m/s2. How much time does it take the
elevator to go from bottom to top?
so i know that d = 180m
a = 1.0 m/ssfor the first part
v = 9 m/s
and for the last part a = -1 m/ss
Im not sure which kinematics to use, there are two that I tried using
d=vit + 1/2at2
and
vf = vi + at
I tried to find the time for the part where the elevator is accelerating by doing
9 = 0 + 1t
so t = 9s
then I tried to find the distance for which the elevator was going up by doing
d = 0(9) + 1/2(1)(92) and got d = 40.5
so then the d for when its decelerating is 139.5 which i plugged into
d=vit + 1/2at2
and tried to solve for t but i ended up getting a weird answer with a square root.
am i approaching the problem the right way? or am i completely wrong?
speed of 9 m/s
v = 9 m/s
d=vit + 1/2at2
and
vf = vi + at
9 = 0 + 1t
so t = 9s
correct so far...
It also travels some distance with constant velocity...
ehild
