Detect EMF with an EMF Meter: How to Use, Effects & Errors
  • Thread starter Thread starter alnywk
    Emf
An EMF meter is designed to detect electromagnetic fields (EMF) and can be used effectively for this purpose. The detection process involves measuring changes in magnetic fields, with the circuit primarily responding to powerline frequency magnetic fields. The amplifier in the circuit, typically an operational amplifier, converts current to voltage, while transistors and diodes are used for signal processing and rectification. Changing the values of capacitors, inductors, or resistors will affect the circuit's response and sensitivity, potentially altering the frequency range and accuracy of measurements. Limitations include potential errors from environmental interference and the meter's design constraints.
alnywk
http://www.electronics-lab.com/projects/science/006/emmeter.gif"
i want to ask
1. is it used to detect emf ?
is it an emf meter
2. how to detect
3. how does am-plifer work ?
transistor used for??
diode use for?
4 if i change other value of capacitor?
inductor?
resistor?
what will the effects of each??
5. what is the error will be?
is there any limitation?
thankss
Well, if the 1mH coil at the left is an open slug, then this circuit will respond to changing magnetic fields. The current-to-voltage converter stage (the opamp) has a single pole 3dB lowpass at around 1kHz, so this circuit looks to be mainly for sensing powerline frequency B fields. Hey, maybe you should offer to visit Buisness Man and help him with his power problems!
https://www.physicsforums.com/showthread.php?t=142685
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
