Mausam
- 27
- 3
This is not a homework.i am not able to understand rotating motional emf .so could u please tell why could we use the effective length to calculate emf in this case .
Maybe that is an easier approach, but not the only one. It can also be solved using the straightforward calculus method. Is the answer given?Mausam said:so could u please tell why could we use the effective length to calculate emf in this case .
Thank you so much for your reply ,yes the answer is given, actually had a doubt that why can we use the effective length though the velocity of every point is different.i mean i am not able to prove that the shape doesn't matter ...so could u please help me prove it in this case ,i am able to prove it when there is no rotation. This is from DC PANDEYcnh1995 said:Is that problem from H C Verma?
This effective length part can be proved using some calculus. Do you know how to set up a differential equation?Mausam said:Thank you so much for your reply ,yes the answer is given, actually had a doubt that why can we use the effective length though the velocity of every point is different.i mean i am not able to prove that the shape doesn't matter ...so could u please help me prove it in this case ,i am able to prove it when there is no rotation. This is from DC PANDEY
I have attached the solution if it helps
If possible can u please elaborate on itcnh1995 said:This effective length part can be proved using some calculus. Do you know how to set up a differential equation?
It's half(B)(w)L²cnh1995 said:Consider the section OCA only. Here, you want to show that arc-length AC is effectively equal to the straight line distance AC. What is the emf induced in the straight line AC if length AC=l?
