I What is the best way to emphasize the proportion of x or y in a dataset?
  • I
  • Thread starter Thread starter adan
To emphasize the proportion of variables x and y in a dataset, the formulas x/(x+y) and y/(x+y) are used to calculate their respective proportions. When x is significantly larger than y, the proportion of x approaches 1, indicating a high emphasis on x. However, if both x and y increase simultaneously, the proportion of x may not necessarily increase, which highlights the importance of using ratios for comparison. An alternative approach suggested involves generating two values, P and N, where P increases with higher x and N increases with higher y, using the formulas P=x/(1+x) and N=y/(1+y). This method aims to provide a clearer distinction in emphasizing the contributions of x and y.
adan
Hi,
There are two variables x and y. I compute a proportion of the x as x/(x+y), and the proportion of y as y/(x+y). I want to emphasize more on the amount of x or y. If x is high then the proportion should be high.
Using the above formulas if x=4229, y= 80, then x proportion = 0.981, when x=4617 and y=91, then x proportion approximately equal 0.981.
I hope I made it clear and I would appreciate any suggestion.
Thanks
Mathematics news on Phys.org
adan said:
Hi,
Do you have a question?
The proportions are, more clearly, the proportion or ratio of x to the sum of x and y and the ratio of y to the sum of x and y. Whichever variable is larger will make for a higher proportion of that variable to the sum of the two variables.
At the same y, it is. If both x and y increase then the proportion of x doesn't have to increase. That's the point of taking the ratio. If you just want to compare absolute numbers, use the absolute numbers.
Thanks all. I think I would like to do something that can't be done using the ratio. The idea is to generate two values (P,N) between 0 and 1. If x is high P increases, and if y is high N increases. Where x and y >= 0.
I will try P=x/(1+x) and N = y/(1+y)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
