Homework Helper
- 30,588
- 7,544
If you were to use a push me pull you arrangement, you might expect 24V peak to peak swing (less the inevitable drops across the amplifying devices), which would give 576W (absolute Peak Power) into a 1Ω load. I have to wonder about the efficiency of 1Ω LS units, too. What flummoxes me about this is that diminishing returns will set in if you try to obtain high voltages for the supply, from a 12V source. Do the manufacturers use inverters to get more oomph?jim hardy said:hmm
450 watts into 4 ohms is 42 volts RMS, 60peak
which means that thing must have a power supply capable of 60volts and almost 40 amps, 2.4KW.
If so , even my preposterous supply would be way undersized for Audiobahn's AT12001DJ .
What size input fuse does it have ?
It seems to me that their advertising is more high power than their amplifiers. boomboom.
