Endurance & maximum range speeds
  • Thread starter Thread starter NTW
    Maximum Range
Maximum endurance and maximum range speeds are related by the factor 3^0.25, but a clear derivation is sought. A provided MIT article addresses the origin of this relationship. However, the discussion highlights that the dynamics can vary between power-producing and thrust-producing powerplants. Additionally, real-world applications of these principles are more complex than theoretical models suggest. Understanding these nuances is essential for accurate analysis in aviation contexts.
NTW
Hello all...
I know that it can be derived, from first principles, that maximum endurance and maximum range speeds are related by the factor 3^0,25.
But I haven't been able to find a derivation. Could anyone here help...?
Thanks in advance...
I think it's different for power-producing and thrust-producing powerplants.
The link answers the OP's question about where the "magic number" came from.
But nothing about aircraft is that simple in real life.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
