simmonj7
- 65
An 8.77-kg block slides with an initial speed of 1.58 m/s down a ramp inclined at an angle of 28.5° with the horizontal. The coefficient of kinetic friction between the block and the ramp is 0.69. Use energy conservation to find the distance the block slides before coming to rest.
E = U + K
Non conservative force = E final - E intial
So I first calculated the normal force by doing N = mg cos 28.5 and found that the normal was 75.6079 N.
Then, I knew the frictional force was equal to \mu times the normal vector so I computed that and found that this force was equal to 52.169 N.
Now I calculated E final and E initial. I figured E initial would be (1/2)mv^{2} (U would equal 0 because d=0 initially) where v is in initial velocity stated in the problem and got that this equaled 10.9467. I figured E final would be mgd where d is the final distance we are solving for (K equals 0 because the final velocity is zero since it comes to rest) so I got this equaled 86.0337d.
Then I figured since the frictional force is the non conservative force, I would set that equal to the final energy minus the initial energy so I would get 52.169 = 86.0337d - 10.9467 so I get d = .734.
However, this apparently isn't even close to the right answer. Where am I going wrong? Any help please?
