Energy Conversion: KWH/M2, MWH/CM2 & WATT/M2
KWH/M2 and MWH/CM2 are related but differ by factors of ten due to their units, with 1 MWH/CM2 equating to 10,000,000 KWH/M2. In contrast, WATT/M2 does not include time as a factor, making it distinct from the other two units. The conversion between these units requires careful attention to the metric prefixes, such as milli (m) and mega (M). Misunderstandings often arise from confusion over these abbreviations and their corresponding values. Accurate conversions are essential for proper energy calculations in various applications.
Smile_Face
Hi all,
Dose kwh/m2 and mwh/cm2 and watt/m2 equal? if not what are the relationship between them?
How can convert between them??
Thanks in advance
Smile_Face :)
kwh/m2 and mwh/cm2 are equivalent - they differ by some power of 10. In the numerator k=1000, m=1000000. In the denominator m = 100cm.
watt/m2 is different in that the other two have time as a factor and this doesn't.
Thanks for replying :)
1 mwh/cm2 = 0.1 kwh/m2 is that right??
incorrect. You are off by a factor of one hundred million.
1 megawatt hour = 1,000,000 watt hours
1 kilowatt hour = 1,000 watt hours
1 meter = 100 centimeters
So
1 megawatt hour per square centimeter = 1000 kilowatt hours per square centimeter.
since there are 100 centimeters in a meter there are 10,000 square centimeters in a square meter.
So 1000 kilowatt hours per square centimeter = 1,000 x 10,000 kilowatt hours per square meter = 10,000,000 kilowatt hours per square meter.
I spelled everything out because I think you were confused by the abbreviations. You lost sight of what the units actually are.
Be careful with upper/lowercase in prefixes:
m = milli = 1E-3; M = Mega = 1E6
p = pico = 1E-12; P = Peta = 1E15
(and there´s deci and deka, of course)
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
