Energy dissipated in a resistor during a time interval?
The discussion centers on calculating the energy dissipated in a resistor during a time interval of 0 to 0.4 seconds. The initial approach incorrectly assumed constant voltage, leading to a power calculation of 40.96 Watts. The correct method involves integrating the variable voltage function, Vs = 400t^2, to find the instantaneous power, P(t), and subsequently integrating this power over the specified time interval. The final energy dissipated is calculated as 16.384 Joules using the correct variable voltage approach.
  • Understanding of Kirchhoff's Voltage Law (KVL)
  • Familiarity with power calculations in electrical circuits
  • Knowledge of integration techniques in calculus
  • Basic concepts of resistive circuits and Ohm's Law
  • Learn about variable voltage sources and their impact on circuit behavior
  • Study integration techniques for power calculations in electrical engineering
  • Explore the use of differential equations in circuit analysis
  • Review the principles of energy conservation in electrical systems
Students in electrical engineering, physics enthusiasts, and anyone involved in circuit analysis and energy calculations in resistive circuits.
mkematt96
P = I*V energy dissipated = wr = ∫ ( P *dt) ... t is from 0 to .4 seconds vs = 400t^2 = 400 * (.4^2) = 64 V
Using KVL I said Vs ( 64 V) = 100 * i ... I found that I was 64/100 = .64 amps. I then said power is .64 amps ^ 2 * 100 ohms = 40.96 Watts. I then integrated 40.96 Watts with respects to time ... Energy dissipated = wr = ∫ ( 40.96 Watts *dt ) from 0 to .4 seconds = 40.96 * .4 = 16.384 J.Where did I go wrong?
The 40.96 is not the power at ##t<0.4## s. You calculate as if the voltage was a constant 64 V from ## t= 0 ## to ##t=0.4 ## s.
So then if the voltage is changing I could integrate with respect to time: Vs = ∫ 400t^2 dt from 0 to .4 s which is equal to 8.533 V then divide by 100 ohms to find the current .08533 amps. Then integrate power with respect to time: Wr= ∫ ( .08533^2 * 100) dt from 0 to .4 sec ?
Aren't you doing something similar again ? Why integrate twice ? Use your own relevant equation ##\displaystyle \int_0^{0.4 {\rm s}}\; P(t) \;dt ## where you substitute an appropriate expression for ##P(t)## :cool:
9K
  • · Replies 32 ·
9K
12K
  • · Replies 21 ·
