Energy Eigenvalue for a Two State System
jameson2
The Hamiltonian for a two state system is given by H=a(|1><1|-|2><2|+|1><2|+|2><1|) where a is a real number. Find the energy eigenvalue and the corresponding energy eigenstate.
I don't know how to start, I'm looking for a hint rather than the answer.
It's probably easier to translate to an explicit matrix form by thinking of the states as vectors
|1\rangle = \begin{pmatrix} 1 \\ 0 \end{pmatrix} , ~ |2\rangle = \begin{pmatrix} 0 \\ 1 \end{pmatrix}.
Once you've solved the problem using that familiar notation, you can go back and figure out how you could have done it using the bra-ket notation. Also note that there are 2 energy eigenvalues and 2 corresponding eigenstates.
If you know the states |1\rangle and |2\rangle are orthonormal, calculate the matrix elements \langle i|H|j \rangle and express H as a matrix.
Thanks guys.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
