false vacuum, negative pressure, repulsive gravity
Let me quote from this link:
http://ned.ipac.caltech.edu/level5/Guth/Guth3.html
The peculiar properties of the false vacuum stem from its pressure, which is large and negative (see box on the right). Mechanically such a negative pressure corresponds to a suction, which does not sound like something that would drive the Universe into a period of rapid expansion. The mechanical effects of pressure, however, depend on pressure differences, so they are unimportant if the pressure is reasonably uniform. According to general relativity, however, there is a gravitational effect that is very important under these circumstances. Pressures, like energy densities, create gravitational fields, and in particular a positive pressure creates an attractive gravitational field. The negative pressure of the false vacuum, therefore, creates a repulsive gravitational field, which is the driving force behind inflation. [...]
The resolution to the energy paradox lies in the subtle behavior of gravity. Although it has not been widely appreciated, Newtonian physics unambiguously implies that the energy of a gravitational field is always negative a fact which holds also in general relativity. [..] The possibility that the negative energy of gravity could balance the positive energy for the matter of the Universe was suggested as early as 1932 by Richard Tolman, although a viable mechanism for the energy transfer was not known.
During inflation, while the energy of matter increases by a factor of 10^75 or more, the energy of the gravitational field becomes more and more negative to compensate. The total energy - matter plus gravitational - remains constant and very small, and could even be exactly zero. Conservation of energy places no limit on how much the Universe can inflate, as there is no limit to the amount of negative energy that can be stored in the gravitational field.
