Energy in different references
  • Thread starter Thread starter hisham.i
    Energy References
hisham.i
I was thinking in special relativity and how does the energy look from one reference to another,
if i consider a body making a circular motion in reference R1, with an angular velocity w1,and a stationary body in reference R2, R1 see that the body in R2 is rotating with an angular velocity |w1|, so the body in reference R2has a kinetic energy 1/2(I*W1^2) from reference R2point of view.
But the idea which is puzzling me is: Is this kinetic energy really exist?!
Hi hisham.i! :smile:
Are you using the rotating body in R1 as a reference frame?
You can't do that in special relativity …
all frames must have uniform velocity and be non-rotational. :wink:
Tiny-tim, that's not correct. You can use any coordinate system you want as long as you don't call it an inertial frame.
hisham.i, your question doesn't have anything to do with relativity. You have the same issue in Newtonian mechanics. The answer is yes, the kinetic energy is different in different coordinate systems.
Hi Fredrik! :smile:
Yes, I agree, but I meant frames "in special relativity", by which I took hisham.i to mean frames related by the Lorentz transformation.
Yes you are right..
but the point is can i really use this energy in the other reference i mean can i generate electricity from this rotation?
yes, everything has energy so far it once had a rest mass..or relativistic mass
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
