Energy of a magnetic dipole in an external B field
The energy of a magnetic dipole in an external magnetic field is described as U=m*B, contrary to the traditional view of U=-m*B. This distinction arises because maintaining a constant current in a loop while moving it requires additional work, leading to the positive energy expression. However, using U=m*B in statistical mechanics yields incorrect conclusions, such as higher temperatures facilitating easier magnetization, which contradicts observed behavior. The force on a current loop aligns with that of a permanent dipole, where U is negative, reflecting the underlying physics of magnetization in ferromagnetic materials. Thus, the correct interpretation hinges on the nature of the dipole and the mechanisms of magnetization.
kof9595995
As in Feynman's lecture on physics vol 2, he showed that the "true energy" of a magnetic dipole(current loop) in an external B field is m*B, not -m*B. Basically the argument is if you want to pull a current loop from infinity to the final position, you must do extra work to keep the current in the loop constant. If you take this energy into account, the total energy will be m*B.
But in statistical mechanics of magnetization, if we use U=m*B instead of -m*B, we will get the opposite results,for example, we will get that the higher the temperature is, the easier to magnetize a material, which is obviously wrong.
How should I explain this?
The reason is (as RF said) that twice as much energy must be provided to a current loop to keep the current constant while it is moved. Although U=+m*B for a current loop, the force on the loop is given by F=+dU/dx so the force on the loop is the same on a permanent dipole. For a permanent dipole, U=-m*B, and F=-dU/dt, giving the same formula for the force. The magnetization in ferromagnetic materials is due to correlated electron spins and not current loops, which is why U=-m*B is apprlpriate.
it makes sense, thanks.
