Energy Problem: Calculating Mean Engine Power & Battery Range
  • Thread starter Thread starter boyblair
    Energy
7 replies · 3K views
boyblair
Hi everyone!
I am having a bit of a problem solving the following question, and would be very grateful for any advice given.
1. Homework Statement
A car is run for 400 hours per year, with a total mileage of 10,000 a year. The car uses diesel and consumes 2,000 litres per year. A litre of diesel cost £1.10 and holds 38.7MJ of primary energy.
a) Calculate the mean engine power?
b) If the engine is 20% efficient overall, how much energy would need to be stored in 95% efficient batteries to give a range of 300 miles on full battery charge?
3. The Attempt at a Solution
a) energy in 2000litres of diesel 38.7MJ * 2000litres = 77400000000MJ
number of seconds in 400hours 3600*400 = 1440000secs
power = energy/time = 77400000000/1440000 = 53750Watts or 53.75kW
b) Really stuck with this part
Welcome to PF!
Hi boyblair! Welcome to PF! :smile:
Yes, that's ok :smile: … but if you write all those zeros, you're very likely to make a mistake so you really ought to write the whole thing as a fraction, and then do a bit of cancelling, rather than doing it in stages. :wink:
efficiency is energy output divided by energy input …
so do that for the batteries (95%) and the engine (20%) separately, then combine them, so as to find how much of the energy put into the batteries wil come out of the engine. :smile:
Hey, thanks for the quick response.
I have attempted part b) and would be grateful for any feedback.
Primary energy consumes in 1 year: 300h*53.75kw=16.1MWh
Energy into 20% efficient motor: 21.5MWh/20%=80.5MWh
Energy supplied to 95% efficient batteries: 80.5MWh\95%=84.7MWh
Many thanks
The efficiency calculations are correct
(though, as before, doing the whole thing together, instead of in stages, would be safer and would look better: 16.1 x 100/20 x 100/95 = 84.7 :wink:).
However, your energy per 300 miles is wrong …
you have multiplied the miles by the power, which is energy per time, instead of energy per mile. :redface:
Thanks for your help tiny-tim.
I have made another attempt at the problem:
Primary energy consumed in 1 year: 400h*53.75kw=21.5MWh
Energy supplied to 95% efficient batteries: 21.5 x 100/20 x 100/95 = 113.2MWh
For 300 miles: 300/10000*113.2=3.4MWh
eugh!
why so long-winded? :rolleyes:
do it the easy way … you want the energy for 300 miles, so read the question carefully, and you'll see it goes 10,000 miles on 2,000 litres, so that's 5 miles a litre … carry on from there :smile:
tiny-tim said:
eugh!
Tiny Tim
Hows it going?
I've found your guidance on this thread and need help with the exact same question funnily enough...
I got to where BoyBlair got to (the long-winded response) - is this the correct answer for this problem, just the long way round?
I've got severe brainblock after 7 days of constant studying and don't even feel like i can count to 10 anymore...
Your response would be greatly appreciated
Ta!
:confused: + :zzz: + :cry: = me!
welcome to pf!
hi jacstar! welcome to pf! :wink:
(just got up :zzz: …)
as Zryn says in the thread you've started on this problem (https://www.physicsforums.com/showthread.php?t=423021"), you need to calculate the energy per distance
as i said before, it goes 10,000 miles on 2,000 litres, so that's 5 miles a litre …
so try it that way, and show us what you get :smile:
