Energy stored in compressed air?
To calculate the energy stored in compressed air, consider the internal energy change based on thermodynamic properties before and after compression. The process is assumed to be adiabatic, meaning no heat is exchanged with the environment. The energy can be determined by multiplying the internal energy difference by the flow rate of the compressed air. Additionally, the first law of thermodynamics states that the sum of heat energy equals the sum of work done, which is essential for this calculation. Understanding these principles will help in accurately determining the available energy in the compressed air.
kevinv
Hi, I am trying to figure out how much energy is stored in compressed air. I have figured out that a device I am looking at compresses about 174 cubic feet per minute into 35 cubic feet and that the temperature would rise from 70 F to 550 F.
I now want to know how much energy, in the form of heat, is available. I am assuming it is an adiabatic process.
Can you help me understand how I calculate the energy?
Thank you!
You can just take the internal energy (after-before) from a table of thermodynamic properties and multiply by the flow rate.
according to thermodynamics 1st law sum of heat energy equal to sum of workdone so u have to calculate amount of energy
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
