Does 1 Joule of Energy Have a Distinct Mass?
  • Thread starter Thread starter aaronfranz
    Energy Matter
The discussion centers on whether 1 joule of energy has a distinct mass, referencing the equation E=mc^2. By applying the formula m=E/c^2, the calculation shows that 1 joule of energy corresponds to a mass of approximately 1.11 x 10^-17 kg. This indicates that energy does have a measurable mass, albeit extremely small. The conversation also touches on the relationship between matter and energy, suggesting they can be converted into one another. The thread concludes with a reference to further reading on the equivalence of mass and energy.
aaronfranz
The equation E=mc^2 and its counterpart m=E/c^2 state that energy and matter are the same thing. (kinda stupid question) Does that mean that 1 joule of energy has a mass? Am I wrong in thinking this? (more to the point, does 1 unit of energy have a distinct mass)
m=E/c^2
1 joule=1kg(m/s)^2
m=1joule/c^2
m=1kg(m/s)^2/299792458 m/s^2
m=1kg(m/s)^2/89875517873681764(m/s)^2
m=1kg/89875517873681764
m=1.112650056053618432174089964848e-17kg
so 1 joule of energy has 1.112650056053618432174089964848e-17kg of mass?
thank you for that link. I will most likely completely read the whole thing through. hopefully it will state weather matter and energy are the same thing or just that they can be converted into each other.
