- 23,752
- 5,953
How many miles were covered in this 26 minutes, and what was the gas mileage?Jay_ said:Okay sir, the drive cycle is not 12 minutes. Its 1597 seconds, or 26 mins. and 37 secs. Under these circumstances, would you say 18 kWh of fuel burnt is too less? Because my coolant calculation average power comes to 49 kW, which is close to your 50.8 kW.
Total energy in 1597 seconds (0.443611 hours) =(49*0.443611) = 21.74 kWh
I calculate the fuel consumption as follows:
mean air flow = 0.0127 kg/sec (from OBD data)
considering air-fuel ratio of 14.7
mean fuel flow = 0.0127/14.7 = 8.6395 x 10-4 kg/sec
In 1597 seconds, total fuel = 1.3797 kg
Calorific value of 47300 kJ/kg , means I burnt 65260.81 kJ = 18.13 kWh
Which part of my calculations is wrong?![]()
Was the engine at temperature during this test, or was it cold to start the test? If the engine wasn't at temperature, then the system was not operating at steady state and all bets are off. Also, of course, when the engine is cold, most of the coolant flow bypasses the radiator.
In my engineering judgement, the calculation of the maximum possible energy consumption, 18 kWh was correct, and it was the radiator calculation that was inaccurate. There are only 3 numbers that go into the radiator calculation: the temperature rise, the heat capacity, and the flow rate. Which of these three do you think is the inaccurate number? Everything points to overestimating the coolant flow rate through the radiator.
Chet
