Edwardo_Elric
- Messages
- 101
- Reaction score
- 0
The 16-ft wing of an airplane is subjected to a lift w/c varies from zero at the tip to 360lb per ft at the fuselage according to [tex]w = 90x^{\frac{1}{2}}[/tex] lb per ft where
x is measured from the tip. Compute the resultant and its location from the wing tip.
Is this what the problem illustrates? This is my own drawing btw
first the drawing looks like this:
then i minus 360lb/ft to 90x^(1/2)lb/ft to make the intensity at x = 0 to 0
then i used a portion of dx and a portion of dR to calculate its area...
then I am going to use ratio and proportion to compute its resultant force in pounds in my
solutions
The latex can't be edited so regard 360ft - lb as 360ft.lb
By ratio:
[tex]\frac{y}{x} = \frac{360ft.lb - 90x^{\frac{1}{2}}lb}{16ft}[/tex]
[tex]y = \frac{360ft.lb - 90x^{\frac{1}{2}}lb}{16ft}[/tex]
Since dR = ydx integrate
[tex]R = \int_{0}^{12} \frac{360ft.lb - 90x^{\frac{1}{2}}lb}{16ft} dx[/tex]
(from 0 to 16)
then i integrated it,
my answer seems to be 576 lb...
The books answer is R = 3840 lb...
can u tell me what is wrong with my solution?
