f95toli said:
First of all, you need to realize that a "clock" is in reality a "thing" (atom, ion, resonant circuit etc) or a combination of "things" that work at a very well specified frequency (or several frequencies that somehow can be related to each other via e/g/. a comb). I don't understand how you would use a neutrino for this; it does not -as far as I know- have any useful Eucharistic frequency.
I don't understand your use of the term "Eucharistic". My wife is a Eucharistic minister, perhaps I should ask her?
In any case, neutrinos probably do have some inherent frequencies. From what I read, they are believed to oscillate because of the different masses of their component neutrino types:
https://en.wikipedia.org/wiki/Neutrino_oscillation
or
http://adsabs.harvard.edu/abs/1980PhRvD..22.2227S
f95toli said:
Secondly, there are already clocks that use entanglement in various ways; a good example would be clocks that use entangled "clock" and "logic" ions (see e.g. the NIST website).
I am not looking for a method of syncing clocks or telling better time. I am simply wondering if, in theory, it is possible to have a clock or a timer that is entangled with an identical clock or timer such that measuring one would tell you what a corresponding measurement of the other would be. From there, you might be able to deduce something about limitations on how precisely the phase of the clock or time-constant on the timer is.
f95toli said:
You still haven't explained what type of experiment you have in mind.
I think I have - but I will give a more specific case:
Say we have found a way to create an EPR pair of neutrinos. When each neutrino in the pair strikes an atomic nucleus, we can determine by the resulting decay particles whether the neutrino has its original identity or has changed. Although there are three possible flavors, for any given neutrino type, only two flavors are possible when detected.
So, with a continuous supply of entangled neutrinos, if they are entangled, I am hoping that whenever each of the is measured at the same time, we get the same decay results in each case - indicating that each neutrino in the pair was in the same phase.
We could then measure the each in each pair at different times to determine the level of correlation that exists as a function of time difference. My guess is that a Bell Inequality would be apparent - because the initial phase of the oscillation is subject to HUP and is only determined at the time of the measurement.
But this is not my area of expertise.
My real question is whether this type of entanglement is theoretically possible.
