Entropy Change Associated with Work
Entropy change associated with reversible work is considered zero because it involves only energy changes among microstates without altering their number. McQuarrie's Statistical Mechanics supports this interpretation, emphasizing that reversible work raises or lowers energy levels without affecting the overall microstate count. In contrast, heating a system increases both the number of microstates and the system's entropy. This distinction highlights the difference between work and heat in thermodynamic processes. Understanding these concepts is crucial for accurately analyzing entropy changes in various systems.
Ali Asadullah
Why entropy change associated with work is zero?
Science news on Phys.org
You sure that's correct?
Reversible work, at least. I've seen an interpretation of this in McQuarrie's Statistical Mechanics. He describes reversible work as a raising or lowering of the energy of all the microstates, but not a change in the number of microstates. Thus, the system entropy is unchanged. During heating, however, the number of microstates changes, and so does the system entropy.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
