Entropy, energy levels and harmonic oscillation.
3 replies · 4K views · last reply
ZCML
A model to describe the vibrations of atoms in a solid is to assume that the atoms are isotropic harmonic oscillators and that the vibrations are independent of the vibrations of the other atoms. We use this model to describe the entropy and heat capacity of Bohrium (B). The entropy is given as 9.797 J/(mol K) at T = 400K
What is the heat capacity of B at T = 600K?
Energy level of a harmonic oscillator: En = hw(1/2 + n) (1 dimension)
Z = the partition function = [tex]\sum[/tex]e^(-En/k*T) = 1/(2*sinh(hw/k*T))
F = -k*T*ln(Z)
The partition function above is valid for a single atom which is only moving in one dimension but to get the correct parition function for motion in 3D one simply does Zcorrect = Z³ which gives the free energy as
Fcorrect = -3*k*T*ln(Z)
S = -([tex]\partial[/tex]F/[tex]\partial[/tex]T)
Cv = T([tex]\partial[/tex]S/[tex]\partial[/tex]T)
From the partition function i can derive the function for S in a straight forward way. I am given the entropy at T = 400 and what i need to know to derive the heat capacity Cv from S is the value for hw. But i can't figure out how to get homework from S given the entropy. I have tried solving the function by the Newton Rhapson method using MatLab but it doesn't want to work. So I am stuck and I am wondering if I am even on the right track. Is there a simple way to find the energy levels of a vibration as in this case when given the entropy?
Ok i think i got a clue (while looking in a book of all places!). What i need is the Einstein temperature of Bohrium and all will be solved nicely. At least i think it will.
I think you can make an approximation sinh(x)=x since x=hw/kT is generally very small for T=400K.
This just reduces to the classical expression 3k.
I also noticed that it is Boron I am working with and not Bohrium as i wrote. I blame the fact that i had to translate the problem to swedish.
