Ideal Gas Entropy: Solving Kardar's Equation IV.33
In summary, Kardar has an error in equation IV.33 of his statistical physics of particles textbook, and he asks for help from his fellow students to verify the error. After reviewing the derivation, it is apparent that the h term is necessary in order for the ST equation to be physically meaningful.
Jolb
419
29
I'm working through Kardar's Statistical Physics of Particles, and I'm in chapter 4 on the part about the ideal gas. Here's a link to that chapter from the book:
http://web.mit.edu/8.333/www/lectures/lec13.pdf
I think he has an error in equation IV.33 but I'd like you guys to make sure of it.
http://img694.imageshack.us/img694/467/kardar.jpg
I think in the top equation of IV.33, the 2∏mE should be 4∏mE, so the final equation should have an 8 instead of a 4. Here's why I think that:
[tex]ln\left (V^N\frac{2\pi^\frac{3N}{2}}{\left (\frac{3N}{2}-1 \right )!} \left ( 2mE \right )^\frac{3N-1}{2}\Delta _R\right ) [/tex]
[tex]=Nln(V)+\frac{3N}{2}ln(2\pi)-\left (\frac{3N}{2}-1 \right )ln\left ( \frac{3N}{2}-1 \right )+\left ( \frac{3N}{2}-1 \right )+\frac{3N-1}{2}ln(2mE)+ln\Delta _R[/tex]
eliminating terms of order 1 or lnN,
[tex]=Nln(V)+\frac{3N}{2}ln(2\pi)-\left (\frac{3N}{2} \right )ln\left ( \frac{3N}{2} \right )+\left ( \frac{3N}{2} \right )+\frac{3N}{2}ln(2mE)[/tex]
[tex]=N\left (ln(V)+\frac{3}{2}ln(2\pi)-\left (\frac{3}{2} \right )ln\left ( \frac{3N}{2} \right )+\left ( \frac{3}{2} \right )ln(e)+\frac{3}{2}ln(2mE) \right )[/tex]
[tex]=N\left (ln(V)+ln(2\pi)^\frac{3}{2}-ln\left ( \frac{3N}{2} \right )^\frac{3}{2}+ln(e)^\frac{3}{2}+ln(2mE)^\frac{3}{2} \right )[/tex]
[tex]=Nln\left (V\left [\frac{(2\pi)(e)(2mE)}{\frac{3N}{2}} \right ]^\frac{3}{2} \right )[/tex]
Did I make a mistake eliminating the terms of lower order? Please help!
Science news on Phys.org
It depends on whether you interpret [tex]2\pi^{3 N/2}[/tex] to mean [tex]2(\pi^{3 N/2})[/tex] or [tex](2\pi)^{3 N/2}[/tex].
It doesn't much matter, the entire expression is in error. The correct expression is
[tex]S=N k_B\log\left[V \left(\frac{4 \pi m E}{3 h^4}\right)^{3/2}\left(\frac{e}{N}\right)^{5/2}\right][/tex]
also known as the Sackur-Tetrode equation for a monatomic ideal gas.
Great, thanks! Silly mistake. The 2 next to the pi vanishes when you neglect terms of order 1.
Kardar's approach is an interesting one--he uses classical physics to derive that incorrect expression and then shows how indistinguishability can be introduced to resolve the error. Putting 1/N! next to omega leads to something closer to the Tetrode-Sackur equation, but without any h. I'm guessing this follows exactly Gibbs' formulation of the Gibbs paradox. I think it's worthwhile to approach statmech from the classical point of view, so I do want to worry about this derivation.
Ok, yes that will help to fix things. Note that in order for the ST equation to be physically meaningful, the argument of the logarithm must be dimensionless. Without the h, its not. Let me know how, in this derivation, the h is finally introduced.
Well this "derivation" is meant to illustrate where and how the classical approach breaks down. The incorrect equation above is not extensive, so Kardar motivates the introduction of 1/N! in the expression for Ω by noting that it ensures extensivity, and he argues its physical appropriateness by discussing indistinguishability.
Here's what he says about h. "Yet another difficulty with the expression IV.47, [which is the 1/N! corrected version of entropy] resolved in quantum statistical mechanics, is the arbitrary constant that appears in changing the units of measurement for q and p. The volume of phase space involves products pq, of coordinates and conjugate moment, and hence has dimensions of (action)N. Quantum mechanics provides the appropriate measure of action in Planck's constant h. Anticipating these quantum results, we shall henceforth set the measure of phase space for identical particles to..." So he sticks in a 1/h3N. Not quite as satisfying as the demonstration of why N! was needed.
It sure isn't. I've been trying to understand Arieh Ben-Naim's derivation of the STE, in "A Farewell to Entropy". He derives it using information theory, and its really informative (LOL - no pun), up to the point where he introduces the h term, then it becomes just as vague.
1. What is Ideal Gas Entropy?
Ideal Gas Entropy is a measure of the amount of disorder or randomness in a system of ideal gas particles. It is related to the probability of finding the particles in a particular state and is a key concept in thermodynamics.
2. What is Kardar's Equation IV.33?
Kardar's Equation IV.33 is a mathematical equation that describes the behavior of an ideal gas in terms of its entropy. It is commonly used to calculate the entropy of a gas at a given temperature and pressure.
3. How is Kardar's Equation IV.33 derived?
Kardar's Equation IV.33 is derived from the fundamental laws of thermodynamics and statistical mechanics. It is a result of combining the ideal gas law with the Boltzmann entropy formula.
4. What is the significance of solving Kardar's Equation IV.33?
Solving Kardar's Equation IV.33 allows scientists and engineers to accurately calculate the entropy of an ideal gas, which is essential for understanding the behavior of gases in various processes and systems. It also has practical applications in fields such as thermodynamics, chemical engineering, and materials science.
5. Can Kardar's Equation IV.33 be applied to real gases?
While Kardar's Equation IV.33 is specifically derived for ideal gases, it can still be used to approximate the behavior of real gases under certain conditions. However, since real gases have more complex interactions between particles, the equation may not provide an exact solution in all cases.
