Enzyme Thermodynamic/Kinetics Question
  • Thread starter Thread starter poohgwai
The discussion centers on the relationship between thermodynamics and kinetics in enzyme-substrate interactions. It questions why products release from enzymes despite high binding affinities, exemplified by a K association of 5,000 1/M. The conversation highlights that while thermodynamically spontaneous binding occurs, the release of the product involves kinetic factors, including distinct rates for association (k_on) and dissociation (k_off) of the enzyme-substrate complex (E*S) and product formation (k_2). The Michaelis-Menten equation is referenced to illustrate these dynamics. It is noted that the states of the enzyme, substrate, and product are metastable and not global energy minima, indicating that there are probabilities and rate constants governing transitions between these states. Additionally, the discussion touches on the role of Gibbs free energy in spontaneous processes, such as G-protein dissociation, and the necessity of ATP in driving reactions against electrochemical gradients, emphasizing the interplay between thermodynamics and cellular energy use.
poohgwai
If it is thermodynamically spontaneous for substrate and product to bind to the enzyme, why does the enzyme ever release the product? For example the K association of a product to the enzyme might be 5,000 1/M, and so is obviously favored. Why does the product eventually leave the enzyme's active site?
Chemistry news on Phys.org
Does the product bind with the same affinity as the starting material? Has the structure of the substrate undergone a change? Does the enzyme change it's structure (shape) when bound to the product vs. the substrate?
The substrate has higher binding.
Which enzyme system are you referring to?
I'm not referring to a specific one. It is more of a thought experiment. I guess what I need help with is balancing kinetics with thermodynamics, and how all of it inter-relates.
There's a lot of material out there you can read; I am looking at "Biological Thermodynamics", Donald Haynie, ch.8 (reaction kinetics).
Basically we can allow there to be a rate k_on for the complex E*S and a rate k_off for the decomposition to E S. They do not have to be the same. Also, there is a rate k_2 for the formation of product P from E*S. Combining them, we get to the Michaelis-Menten equation for enzyme kinetics.
Thermodynamically, the various states E S, E*S, and P are all metastable states. None of them are global minima in the energy landscape, and so there is both a probability associated with the existence of a particular state and a rate constant connecting the various local minima.
In terms of the Gibbs free energy, it is true that some of the processes occur spontaneously- the dissociation of a G-protein, for example, in response to a binding event. The cell then must use GTP (in this case, more often it's ATP) to drive the reaction the other way. Kinases and phosphatases often use ATP for similar reactions. Na-K-ATPase uses ATP to move ions against the electrochemical potential.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
21K
