Epsom Salts browning when dehydrating - burning or normal?
  • Thread starter Thread starter R_Rose
    Normal
Heating Epsom salts (MgSO4) in the oven at 450°F transforms the crystals from white or clear to a solid white powder that can cake together, with some browning observed at the edges. This browning may indicate overheating or the presence of impurities, potentially affecting the integrity of the magnesium sulfate. The discussion raises concerns about whether prolonged exposure to high temperatures can damage the compound, suggesting that the changes in appearance could result from impurities or residues from the pan, such as oven cleaner or soap. The transformation points to the importance of careful temperature control and awareness of potential contaminants when creating desiccants from Epsom salts.
R_Rose
I heated epsom salts in the oven at 450F to make some make-shift desiccants and it went from white (some even clearish) crystals to solid white powder (caked together) with the edges turning a light shade of brown and a deeper brown at the 4 corners of the pan.
Can this damage the MgSO4, is this impurities or what? Is it over-heating? Can it be left in the oven too long and damage the compound?
Chemistry news on Phys.org
R_Rose said:
clearish) crystals
The hydrate.
R_Rose said:
white powder (caked
Mostly anhydrous.
Little oven cleaner residue, soap residue, odd iron from the pan, other sources being cooked out (chromatographed) through your "column packing" in two dimensions, a layer in the pan.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
