Equation for Sinusoidal Function for Mass Above Table Top
The equation for the sinusoidal function representing the height of a mass supported by a spring above a table top is derived from its simple harmonic motion. The mass, initially 0.5 m above the table, is pulled down 0.4 m and released, resulting in a periodic motion with a period of 1.2 seconds. The angular frequency, ω, is calculated as ω = 2π/1.2 s. The final sinusoidal equation can be expressed as y = A cos(ωt) + h, where A is the amplitude (0.4 m) and h is the vertical shift (0.5 m).
  • Understanding of simple harmonic motion
  • Knowledge of sinusoidal functions and their properties
  • Familiarity with angular frequency calculations
  • Basic trigonometry, including the unit circle
  • Calculate the specific values for amplitude and angular frequency in the context of simple harmonic motion
  • Explore the differences between cosine and sine functions in periodic motion
  • Learn about phase shifts in sinusoidal functions
  • Investigate applications of sinusoidal functions in real-world scenarios, such as oscillations and waves
Students and educators in physics, engineers working with oscillatory systems, and anyone interested in the mathematical modeling of periodic motion.
lomantak
A mass is supported by a spring so that it rests 0.5 m above a table top. The mass is pulled down 0.4 m and released at time t=0. This creates a periodic up-and-down motion, called simple harmonic motion. It takes 1.2 s for the mass to return to the low position each time.
Could someone please give me an equation of the sinusoidal function when the height of the mass above the table top is a function of time for the first 2.0 s?
Thanks.
You know the amplitude and you know the frequency (via the period). What more do you need? :)
Your amplitude is given to you (the amount pulled down). The period, 1.2s, is the amount of time it will take to go all the way up, and then back down again.
Remember your unit circle? In this case, the low point corresponds to \cos{\pi}. It makes one full revolution around the unit circle in 1.2 seconds. Since the entire circle (2\pi) is traveled once, then \omega = \frac{2\pi}{1.2sec} where \omega is called the angular frequency. Basically, \omega is the angular rate of change in t seconds.
So, if cosine is at a maximum of 1 and a minimum of -1, then you need to multiply it by the amplitude at its maximum and minimum to get the max and min amplitudes, right?
y = A\cos{(\omega t)}
But, it's 0.5m above the table, so everything is shifted up h = 0.5m
y = A\cos{(\omega t)} + h
I'll leave you to do the actual calculations, but hopefully you see how this works. Also note that cosine and sine are the same function, but cosine is shifted by pi/2 radians. You could also write that as y = Asin( wt + pi/2 ) + h
