What is the equation of the angle bisector formed by two intersecting lines?
  • Thread starter Thread starter V0ODO0CH1LD
    Angle
The equation of the angle bisector formed by two intersecting lines, represented as r = Ax + By + C = 0 and r = Dx + Ey + F = 0, is given by |Ax + By + C|/√(A²+B²) = |Dx + Ey + F|/√(D²+E²). This formulation arises because the angle bisector is the locus of points that are equidistant from both lines. The distances from any point on the bisector to each line are equal, which justifies the equation. Thus, the angle bisector effectively represents all points maintaining equal distance to the two intersecting lines. Understanding this relationship clarifies the geometric significance of the angle bisector in coordinate geometry.
V0ODO0CH1LD
I've seen that if you have two lines: r = Ax + By + C = 0 and r = Dx + Ey + F = 0, you can say the equation of the line that is the angle bisector of r and s is given by: \frac{|Ax + By + C|}{\sqrt{A^2+B^2}}=\frac{|Dx + Ey + F|}{\sqrt{D^2+E^2}}.
Why is that?
I would think to equate the distances from the angle bisector to each line. Is that what is happening here?
Mathematics news on Phys.org
Yes.
Angular bisector of an angle made by two lines is the locus of all points which are equidistant from both the lines. So that the equation of the bisector is given by equating the distances...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
