Equation of family of circles
In summary, the equation of a family of circles touching a given circle and a line is given by ##S + \lambda L = 0##, where S represents the given circle and L represents the line. To find the equation of a specific circle in this family, we can substitute a point of intersection between the circle and the line for S and a desired radius for lambda. However, the equation ##(x - (p + r))^2 + (y - q)^2 = r^2##, which represents a circle with center at (p + r, q) and radius r, does not fit this pattern and may not be applicable in this context.
AdityaDev
527
33
In my textbook, its given that the equation of family of circles touching a given circle S and line L is ##S+\lambda L=0##
So to find the equation of family of circles touching line L at point P(p,q), can i use the same equation taking S to be a circle of radius zero and center at P?
That is, if L is ax+by+c=0 and P is (p,q), then S will be ##(x-p)^2+(y-q)^2=0## and the equation of family of circles will be ##(x-p)^2+(y-q)^2+\lambda (ax+by+c)=0##. Is this correct? such a circle passes through P.
Mathematics news on Phys.org
As it stands, this equation doesn't make sense to me. I don't know what it means to add a circle and a multple of a line, let alone how they could add to zero. Is there some context here that you aren't showing?
Your image doesn't show any coordinate system, but your equations here assume that there is one. Is the line vertical? If so, its equation will be x = k for some constant k.
If the radius of your circle is 0 and its center is at (p, q), this is a degenerate circle (a single point). Note that if ##(x-p)^2+(y-q)^2=0##, then the only solution is x = p, y = q.
I don't understand where this equation comes from: ##(x-p)^2+(y-q)^2+\lambda (ax+by+c)=0##.
I have gone through coordinate geometry by S.L.Loney and I found the same thing.
The equation of any curve passing through the points of intersection of a given curve S and line L is S+kL=0.
This equation is correct because the resultant equation passes through the two points of intersection.
Similarly, the equation of a circle passing through the angular points of a quadrilateral whose side equations are ##L_1,L_2,L_3,L_4## is given by
##L_1L_2+\lambda L_3L_4=0##
Lambda is a parameter. Its not a vertical line. Its just a rough diagram.
Yes. They add to zero when you substitute the point of contact of the given circle and the line. This is how the family of circles is specified. They all have to touch that point.
As a guess, this equation is some notation whose meaning is not obvious to someone without the book you cited. It is no mathematically meaningful to "add" a circle and a multiple of a line.
An equation doesn't pass through points -- it is not a geometric object. A given point can satisfy an equation (i.e., make the equation a true statement).
Again, I don't see how this makes sense, unless it is notation that is not to be taken literally. If, as you say, L1 is an equation, then it's not something that can be used in an arithmetic expression.
Here's an example.
Let E1 be the equation 2x + 3y = 5
Let E2 be the equation x2y = 1
How is E1E2 meaningful? We would have (2x + 3y = 5)(x2y + 3y = 1). I have never seen any mathematics text talk about multiplying one equation by another.
To get back to what you originally asked about, let me make a simplifying assumption; namely, that line L is vertical, and its equation is x = p. If C is any circle that touches the point (p, q) and whose radius is r, then its center must be at (p + r, q). The center of the circle has to be on a horizontal line that intersections the vertical line at (p, q).
The equation of the circle would be ##(x - (p + r))^2 + (y - q)^2 = r^2##. Note that if r = 0, this equation simplifies to ##(x - p)^2 + (y - q)^2 = 0##, and we get only the point (p, q). Also, if we allow r to be negative, we get circles on the other side of the vertical line. In this case, we would take the radius of the circle to be |r|.
Likes AdityaDev
Related to Equation of family of circles
What is the equation of family of circles?
The equation of family of circles is a mathematical equation that represents a collection of circles that share common characteristics, such as having the same center or radius.
What are the variables in the equation of family of circles?
The variables in the equation of family of circles are the coordinates of the center point (h,k) and the radius (r).
How do you graph a family of circles?
To graph a family of circles, you need to plot the center point (h,k) on a coordinate plane and then draw a circle with the given radius (r) around the center point. Repeat this process for each circle in the family, making sure to use the same center point and varying the radius values.
What is the significance of the equation of family of circles in mathematics?
The equation of family of circles is significant in mathematics because it allows us to represent a group of circles with a single equation, making it easier to analyze and solve problems involving circles.
Can the equation of family of circles be used in real-life applications?
Yes, the equation of family of circles can be used in real-life applications such as in engineering, physics, and architecture. For example, it can be used to calculate the path of a moving object in circular motion or to design circular structures such as bridges or roundabouts.
  • General Math
  • General Math
  • General Math
  • General Math
