Equilibrium at Constant Velocity
To solve the problem of three forces acting on a moving object at constant velocity, the resultant of the first two forces must be calculated. The first force is 80.0 N directed north, and the second is 60.0 N directed west. Using Pythagorean theorem and trigonometry, the magnitude and direction of the resultant force can be determined. The third force must then equal the negative of this resultant to maintain equilibrium and ensure the object continues moving at constant velocity. Gravity is not a factor in this scenario, and the focus should remain on the forces provided.
Tater
Hi there. This problem is very basic but I really cannot figure out how to solve it. I'm missing something but I have no clue what it is.
Three forces act on a moving object. One force has a magnitude of 80.0 N and is directed due north. Another has a magnitude of 60.0 N and is directed due west. What must be the magnitude and direction of the third force, such that the object continues to move with a constant velocity?
Force X Y
F1 F1Cos90 F1Sin90
F2 -F2Cos90 F2Sin90
W 0 -W=-mg
F1Cos90-F2Cos90+0=0 (Then divide by Cos90)
F1=F2=>F
FSin90+FSin90=mg
2FSin90=mg
F=mg/2(Sin90)
F=mg/2(1)
F=mg/2
I would be very thankful if someone could please tell me what I'm doing wrong and what I should be doing so that I may learn from this question.
There is no mention of gravity in this problem, so do not try to include it in your solution. Calculate the resultant of the two given forces (magnitude and direction)..one force is along the y-axis and the other along the x axis...use pythagorus and basic trig to calculate it. Then what must the third force be to keep the object moving at constant velocity (HINT: Use Newton 1).
