Equilibrium constant always valid?
The relationship DG = -RTln(K) is valid for reversible processes at equilibrium, but it does not hold for irreversible reactions or systems that are not at equilibrium. In cases where a reaction is coupled with irreversible steps, such as A<==>B--->C, the initial and final states cannot be analyzed using this expression. The approximation that allows for the use of this equation in mixed systems relies on the assumption that the reversible step is fast compared to the irreversible step. For irreversible processes, while a change in free energy (DeltaG) can be defined, it cannot be determined from equilibrium measurements. Thus, the application of this thermodynamic relationship is limited to specific conditions.
arwelbath
DG = -RTln(K) always valid?
Hi,
For a reaction at equilibrium, A<==>B, then the free energy can be defined as
DG = -RTln(K), where K = /[A].
This is fine for an isolated equilibrium. But suppose that the system is not isolated so that A<==>B--->C for example, or if is part some even more complicated kinetic scheme. Does the relationship for DG still hold?
Please help with this one, am getting conflicting advice from different people!
Ta.
Yes, K is the same always - unless temperature changes. What you have is an application of Le Chatelier's Principle, whereby the concentration of B will shift so and [A] may be different but yield the same K.
Thanks, but didn't frame my question quite right. What I mean is that is the relationship (DG = -RTln(K)) always true even if it isn't an isolated equilibrium? Is it okay for closed and open systems too?
arwelbath said:
(snip)suppose that the system is not isolated so that A<==>B--->C for example,
irreversible as written, therefore, NO.
The expression is a valid description of the relationship between the initial and final states of a reversible process (or reaction) --- open, closed, riding a float in Mardi Gras, running for public office, running from the law --- in other words "ALWAYS" --- tack on an irreversible "sink" for the "final" state (C in your example), and the process is no longer reversible, the expression no longer includes the final "final" state.
Initial, final, and reversible.
Thanks Bystander.
The reason I ask is that this very often seems to be done. I could ref a number of DSC papers (for example) where people study coupled reversible and irreversible processes, and interpret the thermodynamics of the reversible process using that expression for the free energy in terms of K.
For example, the A<==>B---->C mechanism is ususaly called the Lumry-Eyring mechanism. The prcedure seems to be that as long as A<==>B is kinetically fast compared to B--->C, then they assume that the AB transition is approximately at equilibrium and can be analysed using classical reversible thermodynamics. Exactly where this approximation breaks down in terms of the relative reaction velocities seems to be not discussed however.
So my next question would be where to begin in terms of properly analysing thermodynamics of a coupled reversible / irreversible system like this? I can do the kinetics and get Arrhenius type activation energies for each process. But, the really interesting info would be DeltaG A-B and DeltaG B-C. Which brings me back to a question I've posted on here before. Is DeltaG defined for the irreversible process, and if so, how would it be calculated?
Irreversible process? del G? Yes. del G nought (the std. state that shows up in del G nought = -RTlnK)? Not in a way that can be determined from equilibrium measurements of reactant and product activities --- "irreversible" means that the system is never at equilibrium, del G is never zero, and del G nought can never be equated to RTlnK.
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
