Equilibrium Question -- Thrust versus Lift....
The discussion centers around calculating lift and resistance for an aircraft given specific thrust and weight values. The user initially believes lift equals thrust and resistance equals weight, but acknowledges the need for more information to solve the problem accurately. They mention an angle of 30 degrees, which suggests the use of trigonometric functions to find the correct values. Ultimately, the user concludes that they no longer require assistance. Understanding the relationship between thrust, lift, and resistance is crucial for solving such equilibrium problems in physics.
Rhineland
Given:
Thrust: 103000 N
Lift = ?
Weight = 86500 N
Resistance = ?
I'm just to figure out the value of resistance and lift.
I can't seem to figure out a way to find out resistance, but with lift I believe it has something to do with the weight.
Maybe I'm missing something, but the answer appears trivial to me, and this is not an Advanced problem. The "Lift" is equal to the thrust and the "Resistance" is equal to the weight. Perhaps someone else will supply something different from that, but that is what I think the answer would be.
Likes berkeman
Thread moved to Intro Physics. :smile:
Technically you cannot solve this problem without more information. Is the aircraft flying "in equilibrium" or is it accelerating?
Likes Charles Link
I forgot to mention that there was an angle of 30 degrees. Just had to use cos 30. Thanks for taking the time to reply back! No help needed anymore.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
