Equillibrium ladder on a wall problem
  • Thread starter Thread starter odie5533
    Wall
The discussion revolves around solving the equilibrium problem of a ladder leaning against a wall. The user initially calculates the normal forces and friction but struggles with the torque equations, leading to incorrect results. A key error identified is the use of cosine instead of sine for calculating torque, which affects the normal force at the wall. After correcting this and recalculating, the user finds that the total force from the ground is approximately 1570 N, which is valid as it remains below the maximum static friction. The conversation highlights the importance of accurate trigonometric functions in torque calculations for equilibrium problems.
odie5533
http://img90.imageshack.us/img90/4989/scanuy8.png
http://img125.imageshack.us/img125/8163/fbdzh7.png
Been working on this one for at least an hour now =/
n_{1} is the normal force of the wall on the ladder
n_{2} is the normal force of the ground on the ladder
\sum F_{x} = f_{s} - n_{1} = 0
f_{s} = n_{1}
\sum F_{y} = n_{2} - m_{ladder}g - m_{weight}g = 0
n_{2} = 150(9.8) = 1470N
\tau = Fdcos\theta
\theta = sin^{-1}(4.5/5) = 64
\sum\tau = (n_{1})(5)cos(64) - (m_{ladder}g)(2.5)(cos(64)) - (m_{weight}g)(5)(cos(64)) = 0
n_{1} = 1131N
And since f_{s} = n_{1}, the answer I get is 1131N, which is wrong. If anyone can see where I messed up, I'd greatly appreciate any help.
It just occurred to me that it is asking for the entire force from the ground, not just the frictional force.
F_{tot} = \sqrt{n_{2}^2 + f_{s}^2} = \sqrt{1131^2 + 1470^2} = 1852 N
Still off =/
*EDIT* using the answers as I guide, I figured out a way to make my calculations match an answer, but I have a feeling it is wrong...
f_{s-max} = n_{2} * \mu_{s} = 1470(0.40) = 588N
F_{tot} = \sqrt{n_{2}^2 + f_{s-max}^2} = \sqrt{1470^2 + 588^2} = 1583 N
Which matches an answer, but I think the ladder should be sliding down with all the weight...
Still off =/
well I'm not sure what you got anymore, but i notice that in your original post you incorrectly calculated the torque of the normal force at the wall you used cos64 when you should have used sin 64...that should give you the correct answer..the friction force at the base is not necessarily (mu)n2, it is equal or less than that value depending on your corrected torque equation.
n_{1}(5)sin64 = (M_{ladder}g)(2.5)cos64 + (M_{weight}g)(5)cos64
n_{1} = 550
F_{tot} = \sqrt{550^2 + 1470^2} = 1570
And 550 < f_{s-max} of 588 :D
Thanks for the help!
You're welcome, you did a good job with this problem, just a small trig error threw it off. It's sometimes easier to use torque as the product of the force times the perpendicular distance rather than torque = Fdsintheta, where theta is the angle between the force and displacement vectors, because it's easy to mess up on the correct theta value.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
