Derivator
- 147
Hi,
according to the equipartition theorem
<p_k \frac{\partial H}{\partial p_k}> =k_bT (where H depends on f generalized coodinates p and q and f is the number of degrees of freedom)
the temperature for a system of particles should be given by the result of the following derivation
<\sum_k^f p_k \frac{\partial H}{\partial p_k}> =\sum_k^f k_bT
<\sum_k^f p_k \frac{\partial H}{\partial p_k}> = f k_b T
now using f=3N-d where N is the number of particles and d the number of 'constraints', one gets:
<\sum_k^{3N-d} p_k \frac{\partial H}{\partial p_k}> = (3N-d) k_b T
using \frac{\partial H}{\partial p_k}=2\frac{p_k}{2m} one gets:
<\sum_k^{3N-d} \frac{p_k^2}{2 m}> = \frac{3N-d}{2} k_b T
however, the common result is:
<\sum_k^{N} \frac{\vec p_k^2}{2 m}> = \frac{3N-d}{2} k_b T (note, that p_k is a vector)
That is, what people seem to do is, they don't write the kinetic energy on the left hand side as a sum of the components p_k, but as a sum over the momentum vectors:
I don't see, how they manage the upper bound 3N-d of the sum. If the upper bound was only 3N, then the last equation for the kinetic energy would be obvious to me. That is, I would understand the following
<\sum_k^{3N} \frac{p_k^2}{2 m}> = <\sum_k^{N} \frac{\vec p_k^2}{2 m}>
where the sum on the left hand side is going over the momentum components of all particles and the sum on the right hand side is going over the momentum-vectors of all particles.
but I don' t see, how people manage to get
<\sum_k^{3N-d} \frac{p_k^2}{2 m}> = <\sum_k^{N} \frac{\vec p_k^2}{2 m}>for an example, please see page 11 of http://www.physics.buffalo.edu/phy411-506/topic3/lec-3-1.pdf (where d=3)
