What Is the Concentration of the Stock HBr Solution?
To determine the concentration of the stock HBr solution, a 20.00 mL sample was diluted to 50 mL, and 18.76 mL of 0.1345 M KOH was used to reach the equivalence point. The moles of KOH were calculated to be approximately 2.52322 moles, which equals the moles of HBr at equivalence. The initial calculation mistakenly used 0.5 mL for the volume of HBr instead of the correct 20 mL, leading to an incorrect concentration. After correcting the volume, the concentration of the stock HBr solution was found to be 0.1262 M. The discussion also briefly touched on the absence of a thank you button on the forum.
a.a
A 20.00 ml stock sample of HBr is diluted to 50 mL. If 18.76 ml of 0.1345 M KOH was required to reach the equivalence point, what is the concentration of the stock HBr solution?
KOH + HBr --> KBr + H20
M = conc. = mol./L
n = V * conc.
n-KOH= V-KOH * conc. KOH = (18.76*10^-3 L) * (0.1345 mol./L) = (2.52322*10^-3 mol.)
=> n-HBr= (2.52322*10^-3 mol.)
V-HBr= 5.0*10^-4 L
conc. HBr = (2.52322*10^-3 mol.)/ (5.0*10^-4 L) = 5.04644 M
I don't think this the right answer but I seem to endup with the right units, can someone please tell me what I am doing wrong and how to go about this question the right way?
Generally you are on the right track, however:
a.a said:
V-HBr= 5.0*10^-4 L
that's not true. 5*10-4 L = 0.5 mL.
Also think whether you should use 20 mL or 50 mL. Question asks for the concentration of the stock solution. Note, that if you will not dilute your sample to 50, you will use exactly the same amount of KOH, so you can omit dilution calculations.
Hi,
I did it over agian and used 20 ml and the answer i got was 0.1262 M
can you please verify?
btw, is there a thank you button on this fourm?
OK
I think there was once, but it was getting too hot of continuous pressing.
